qtschlepper
Dec 23, 2017Star
Wi-Fi connection lost with security Firmware V1.0.9.18_1.2.27 patch on R7000
After installing V1.0.9.18_1.2.27 on my R7000 router, I lose WI-Fi connctivity on both the 5 and 2.4 Mhz bands. The hardware Eithernet connections stay active, and otherwise the router behaves normal...
- Feb 06, 2018
Hi kemuri1000,
Please try this firmware.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
locmer
Jan 01, 2018Aspirant
Same problem here after upgrade to V1.0.9.18_1.2.27 Wifi doesn't work for my mobile devices (Samsung S7 and Xiaomi redmi note 4) but works ok with Mac book and Mac book pro. Reboots do not seems to clear it (temporarily) for me. So downgrading now. Looks like a pretty big regression problem. (Unless this is a flaw in Android on the client side)
- Also the hotfix V1.0.9.20_1.2.28 does not solve this problem
- Factory reset and restore of the con figuration also does not solve this problem.
- locmerJan 01, 2018Aspirant
Going back to V1.0.9.14_1.2.25 solves the problem immediately (no factory reset / reread config needed).
Now figuring out how to file a bug with Netgear
- qtschlepperJan 13, 2018Star
I'm not so hot about downgrading my security patches to keep this up and running. But i'm also not so happy about buying new gear to keep up and decommissioning my perfectly good router.
- rogier64Jan 13, 2018Luminary
You do not need to buy a new router. Option 1, wait for the new firmware from NG. Option 2, flash an alternative stable firmware.
