qtschlepper
Dec 23, 2017Star
Wi-Fi connection lost with security Firmware V1.0.9.18_1.2.27 patch on R7000
After installing V1.0.9.18_1.2.27 on my R7000 router, I lose WI-Fi connctivity on both the 5 and 2.4 Mhz bands. The hardware Eithernet connections stay active, and otherwise the router behaves normal...
- Feb 05, 2018
Hi kemuri1000,
Please try this firmware.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
locmer
Jan 01, 2018Aspirant
Going back to V1.0.9.14_1.2.25 solves the problem immediately (no factory reset / reread config needed).
Now figuring out how to file a bug with Netgear
qtschlepper
Jan 13, 2018Star
I'm not so hot about downgrading my security patches to keep this up and running. But i'm also not so happy about buying new gear to keep up and decommissioning my perfectly good router.
- rogier64Jan 13, 2018Luminary
You do not need to buy a new router. Option 1, wait for the new firmware from NG. Option 2, flash an alternative stable firmware.
- qtschlepperJan 13, 2018Star
Well in my case I have over 35 wireless devices in my home including a Ring doorbell and several Chromcasts that I rely on for entertainment. So waiting isn't much of an option for me. I picked up an Orbi 3 pack at Costco, added all my MacID (close to 50) addresses and I'll return it after all the smoke clears. Or not.
- rogier64Jan 14, 2018Luminary
That's a good choice, but not everyone can afford a new router.
