Lknelson
Aug 03, 2021Follower
Wi-Fi name and password did not change
How do I customize the user name and password— I did it during set up but it doesn’t appear to have worked
Aug 03, 2021Guru - Experienced User
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
You could also go to netgear.com/support/
type in your model number.
it'll take you to guides, manuals, and firmware for your specific device
