mattegem
Jun 30, 2021Aspirant
Wi-Fi not available
Both bands have disappeared, leds off on the router. Tried reset to factory settings, firmware updated but nothing. Internet is available I don’t know what else to do….
- Jun 30, 2021
You are welcome. Please mark as resolved.
Kitsap
Jun 30, 2021Master
You have managed to manually turn off the Wi-Fi radios. Neither firmware updates or reset to firmware default settings or cycling the power will change the state of the on/off switch. Once turned off, it stays off until manually turned back on.
When looking from the front of the router, the last two leds on the far right are a combination indicator/switch. The second one in is the Wi-Fi radio on/off switch. Press and hold for two seconds then release. Your Wi-Fi radios should come back on.
This information is in the manual.
