M_T_B
May 09, 2019Aspirant
Wi-fi Repeater unable to discover SSID of R8000P —Nighthawk X6S AC4000 Tri Band WiFi Router
Dear ALL,
I have a router R8000P —Nighthawk X6S AC4000 Tri Band WiFi Router in my home and working well for normal wifi network.
My CCTV DVR is away from my router and physical cabling is not possible, so I tried to use Wi-fi to ethernet converter of Tenda and TPLINK.
Issue : when I set the Tenda router in repeater mode, it can search all ssid in my area but not the one configured on my R8000P —Nighthawk X6S AC4000 Tri Band WiFi Router router.
I tried both 2.4 GH and 5 Gh but unsucceded. tried looking for setting in the configuration of R8000P —Nighthawk X6S AC4000 Tri Band WiFi Router but could not find anything to make SSID visible in Tenda repeater router.
PLease suggest me how can I get this done?
Thanks,
Manoj
Yes I would suggest upgrading to the latest firmware.
DarrenM
- M_T_BAspirant
Update : The fimware verion I am using is the one came with router V1.1.3.2_1.1.74
The latest available firmware is R8000P-V1.4.1.30_1.2.26, would it be helpfull to upgrade the firmware?
Thanks
Manoj
- DarrenMSr. NETGEAR Moderator
DarrenM
- M_T_BAspirant
Hi Darren,
Thank you for suggestion. The issue has been resolved after upgrading firmware from V1.1.3.2_1.1.74 to V1.4.1.30_1.2.26.
I have successfully deployed the wirless bridging between Netgear and Teanda router, CCTV is connected with cable to Tenda and has became online now :). My purpose has been solved.
Thank you very much.
