cyberwasp
Oct 13, 2021Star
WIFI 6
Could someone please point me to the right forum. When I pull down the menu for the model of m,y router. I can't for the life of me find it listed at all. Accoring to the box and on the routers...
Oct 13, 2021Guru - Experienced User
it might not show but this is the forum for your device:
- cyberwaspOct 13, 2021Star
Ok, since I'm in the right place. They say that the RAX50 is a wifi 6 router. If it is, why aren't there any Wifi 6 in the menus? All I can find are 2.4 and 5. Very odd
- plemansOct 13, 2021Guru - Experienced User
Wifi 6 is 2.4ghz and 5ghz. the new 6E standard includes 6ghz.
- michaelkenwardOct 14, 2021Guru - Experienced User
Not really.This place is for standard Nighthawk WiFi Routers.
Nothing wrong with asking here but for specialist input from fellow users try here.
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Same as before but in a reader friendly format.
