Robm65's avatar
Robm65
Initiate
Dec 06, 2020
WIFI Access Point
Hello  I am looking to run a Ethernet cable from my existing  R7000 AC1900 Nighthawk Wifi Router to my home office [approx 20m ] using CAT6 cable for a Wifi Access Point for use inside the office ...
  • plemans's avatar
    Dec 08, 2020
    You can go with an extender or even a router and run the router in AP mode.
    I've used that route plenty and it  gives you the option of a backup router in case you need it.
    Or even upgrading your current router and turning the old one into an access point.
    Several options going for you.
