sirsmedley
Jan 20, 2022Follower
WIFI and Ethernet simultaneously
I've had the R6700v2 Nighthawk AC1750 for a while and was wondering if you can have both WIFI and Ethernet working simultaneously. If so, how is it set up? I moved my PC closer to where the int...
- Jan 20, 2022
yea both wifi and ethernet work at the same time. Did you accidently turn off the wifi on your router? There's a wifi button on the right of your router that if you press it for 2 to 3 seconds it can be turned on/off.
wcalifas
Jan 20, 2022Prodigy
