ricko2001
Apr 30, 2021Aspirant
Wifi AP using PoE
I'm installing an ethernet cable in my home in a hallway and want to put an WiFi AP there. No mains power available. It seems only business models use PoE. Any recommendations?
- May 01, 2021
You can use business class equipment in a home. They will sell it to you.
I'd only make sure to keep an eye out for those that require a subscription for certain capabilities.
May 01, 2021Guru - Experienced User
I've used the WAX218 with great success. There's a bunch of other models so I'd just search for what features you'd prefer.
You can go here:
Wireless Access Points - Wifi Access Points | NETGEAR
and there's a filter for POE. Easy way to see whats available and covers your needs.
- ricko2001May 01, 2021Aspirant
Those are all n the "Business" section.
Will netgear sell one to me for home use?(I am retired SW developer, so I should be able to figure it out)
- plemansMay 01, 2021Guru - Experienced User
