juanamneal's avatar
juanamneal
WiFi Boost for Nighthawk R3800
Hello,   We moved to a new place in a new state. Our internet went from Cox fiber optic to Atlantic Broadband. The new place is double the size of the old one (4100 sqft). The internet is slower bu...
  • plemans's avatar
    Mar 31, 2021
    The R8300 is a pretty solid router and so is the arris SB8200 as a modem.
    Both highly capable.
    Either going with an extender or adding a mesh system can help with added coverage.
    There isn't much better modem than the sb8200 unless you plan on going to something like the cm2000 with a 2.5gig port on it but thats a bit pointless.
