767pilot
Oct 05, 2017Tutor
Wifi broken after firmware update
Everything was working fine and I decided to do the firmware update that I was told about via email from Netgear today. Everything went well except now I can turn on the wifi. I have tried every sett...
- Oct 06, 2017
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
First note down the settings – screen grabs can help here.
michaelkenward
Oct 06, 2017Guru - Experienced User
767pilot
Oct 06, 2017Tutor
Thank you, Michael. I'm glad that I didn't have the same problem that Mike did and as frustrated as I was, I am sure he feels even worse. No where in the directions did I see anything about doing a reset. If it's in there I missed it, if it's not in there perhaps it needs to be.
Anyway, thanks for your help
- michaelkenwardOct 06, 2017Guru - Experienced User
Hard to disagree with that.
Maybe the technology does not allow Netgear to pass on such alerts.
- Mikecherry1Oct 06, 2017Aspirant
I was fortunately able to just power cycle the router after waiting long enough to know that the router wasn't going to correct itself with the firmware initiated reboot. After the power cycle, all functionality was restored and the firmware is shown as updated, so looks like I'm also in the clear, thanks!
