767pilot's avatar
Oct 05, 2017
Wifi broken after firmware update
Everything was working fine and I decided to do the firmware update that I was told about via email from Netgear today. Everything went well except now I can turn on the wifi. I have tried every sett...
  • michaelkenward's avatar
    Oct 06, 2017
    Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So a factory reset is the first thing to try if you have problems with new firmware.
    First note down the settings – screen grabs can help here.
