767pilot
Oct 05, 2017Tutor
Wifi broken after firmware update
Everything was working fine and I decided to do the firmware update that I was told about via email from Netgear today. Everything went well except now I can turn on the wifi. I have tried every sett...
- Oct 06, 2017
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
First note down the settings – screen grabs can help here.
Des71
Oct 06, 2017Tutor
The firmware update for my R6400 disabled my WiFi and I tried rebooting it with no success. I didn't even have the option to enable the SSID broadcast on the WiFi settings. I decided to change back to the previous Firmware Version (V1.0.1.24_1.0.18) and after it was installed and the router rebooted, everything worked. It was very frustrating to waste an hour and experience needless stress on a Friday. Here's the link to the R6700 firmware, if you want to try the same thing: https://www.netgear.com/support/product/R6700.aspx#download
- michaelkenwardOct 06, 2017Guru - Experienced User
Rebooting already happens during the upgrade process. Doing it again gets you not further.
Before going back to old firmware, with the security issues that this entails, do a factory reset.
If that fails then you could try older firmware.
- Des71Oct 06, 2017Tutor
I went back to the older firmware with success.
And to the old security issues.
Did you try a factory reset?
The choice is yours. I mentioned it so that other people know that if they are concerned about security can try something else.
