tandilero's avatar
Mar 29, 2022
WIFI Button Nighthawk X10 (AD7200)
I need to know if there is anyway to set wifi on/off button to disable guest network only. That way the admin people can continue to use internet while easily turning off guest access without using t...
  • michaelkenward's avatar
    Mar 30, 2022
    Not the button, but you don't have to use the graphical user interface (GUI).
    genie | Product | Support | NETGEAR
    The Netgear genie for your operating system can do it. So can the Nighthawk app.
    Not as simple as pressing a button, but easier than firing up a browser.
    The app can even do it remotely.
