tandilero
Mar 29, 2022Tutor
WIFI Button Nighthawk X10 (AD7200)
I need to know if there is anyway to set wifi on/off button to disable guest network only. That way the admin people can continue to use internet while easily turning off guest access without using t...
- Mar 30, 2022
Not the button, but you don't have to use the graphical user interface (GUI).
genie | Product | Support | NETGEAR
The Netgear genie for your operating system can do it. So can the Nighthawk app.
Not as simple as pressing a button, but easier than firing up a browser.
The app can even do it remotely.
michaelkenward
Mar 30, 2022Guru - Experienced User
