mdodge2007
Mar 09, 2021Follower
Wifi Cable Modem router C7000v2 Ethernet stopped working suddenly
Got on my computer today and found I had only access to internet through wifi. The ethernet ports on my AC1900 seemed to stop working. There are no lights on any of the connected ports but the wifi...
antinode
Mar 10, 2021Guru
> [...] Is there anything I can do here or is my modem dead?
The Ethernet LAN part of it apparently is. If you had even one good
port, then you could attach a (cheap) Ethernet switch, but, with none,
I'd call it a goner.
