klebel
Oct 08, 2020Aspirant
Wifi design for new large house?
I am moving into a new house this month that is 5500 sq/ft and on 5 acres. HUGE change for our family. The house is wired with Cat5 throughout. So it will be easy for me to add access points. I a...
- Oct 08, 2020
I know you're not needing a "real mesh" but I'd actually look at it.
Something like the RBK43 version with a wired backhaul would have the same performance as the 50 series because the difference is in the backhaul. Plus it'd give you seamless roaming, the ability to add more satellites as needed, and even the option to use a wireless backhaul if you wanted.
Plus if you look at it, netgears consumer line up of devices doesnt have an extender/AP that functions with mesh (same ssid capabilities) before moving into the business grade equipment which gets expensive.
Not saying you have to but the single ssid function with seamless roaming works great in larger homes and is worth it.
If you wanted a higher functioning router to control it all, you can do that and just run the orbi setup in access point mode. I've done that before with great success.
Oct 08, 2020Guru - Experienced User
klebel
Interesting. This is exactly why I asked the question. I believe that I read that the Orbi didnt support wired backhaul on a switched network? Is that still true? I have a Netgear Gigabit ethernet PoE+ switch that everything is going to be plugged into.
- plemansOct 08, 2020Guru - Experienced User
I have a gs716tv2 on my network plus other unmanaged switches and it works fine. I've ran up to 4x satellites with this setup.
