sbraithw
Mar 11, 2017Aspirant
Wifi Devices Cannot Connect
This started yesterday. Wired connections work fine but I cannot connect wirelessly. The button on the router is lit for wifi. I tried enabling a guest network with a password and the same thing h...
- Mar 14, 2017
I figured out the problem. No need to do a factory reset. I have 3 Directv receivers on my network as part of the whole home DVR. One of the receivers was causing an IP conflict. Once I unplugged it from the network, all my wireless devices connected. In my case it was Directv but if someone else had the same issue it could be any device causing the conflict. I unplugged all the wired devices from the network and it worked then unplugged each device to verify if it was causing the conflict. This took a while to figure the exact device but was well worth it. Thanks for all the help.
michaelkenward
Mar 12, 2017Guru - Experienced User
sbraithw wrote:It's been rebooted many times.
You didn't say that, which is why I mentioned it.
sbraithw wrote:Another thing I should mention is that there a few devices that will connect.
Yet more new information.
Knowing that, how about telling one of the troublesome wifi clients to forget the network and then try to reconnect?
sbraithw wrote:I guesss the factory reset is always an option.
Always worth trying as a last resort.
sbraithw
Mar 14, 2017Aspirant
