Rkedonnay's avatar
Oct 20, 2020
WIFI Devices Issues
All devices are showing wifi adapter issues. When connected with ethernet connection, no problems.  Have used Nighthawk to verify update of latest version of firmware.  Any suggestion?  Does this ind...
  • plemans's avatar
    Oct 21, 2020
    1 & 2  So by adding multiple devices to the 5ghz band, is it reasonable to move a printer and an iPhone to the 5ghz band and leave the laptop and desktop with second channel? These are all my devices. ---Printers take mininal data. It'd be fine on the 2.4ghz. the desktop/laptop/streamers should be on the 5ghz.
    3 & 4 Your advice has given me a good reason to give the factory reset a try. I don't really want to purchase if this one still has good life remaining. After factory reset, am I correct in that this would be similar to a new installation?----It should I will need to do the reset today around 3 p.m (EST) and hope it's completed by 6 p.m. Zoom conference.  If this a reasonable time frame?  -----Maybe? Depends on your capabilities. If its a job sensitive call, i might hold off until afterwards. Its usually takes me 5-10 minutes but I do this weekly/monthly because I swap devices so much.
    You advice is so helpful. Thank you so very much.
