DGN2200MFollowerJun 15, 2021Wifi DGN2200M Buongiorno, volevo gentilmente sapere se possibile attivare/disattivare il wifi a piacimento e mantenere solo connessione via cavo? Grazie, saluti
plemansGuru - Experienced UserJun 15, 2021There's a wifi on/off button on the front panel. https://www.netgear.com/support/product/DGN2200M.aspx
