_chris
Apr 29, 2019Tutor
Wifi dropping connections constantly, I have tried everything
I cannot seem to solve this one. I'm just so frustrated that I'm ready to get a new router that isn't Netgear (maybe Ubiquiti/UniFi?). I have been very happy with this rotuer for years, but I just ca...
- May 06, 2019
Currently using 1.0.9.32 without issue for 72 hours now.
The .42 firmware has a bug with the VPN so I can't use that one since I use the VPN alot.
Wigglez
Aug 28, 2019Aspirant
where do I find 1.0.9.32.? I looked at downloads and not listed. thanks for your help
_chris
Aug 28, 2019Tutor
You can find it here:
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Changing firmware isn't like installing a program on your computer, make sure you follow the instructions and read over the "important note" so you dont break your router. Also, when you downgrade, make sure you factory reset before AND after installing the firmware (to be safe).
