Minnie73
Nov 13, 2021Aspirant
WiFi dropping
Nighthawk AC1900 The WiFi drops out about every 2 days. Takes about 4 modem restarts to get it to stay connected. The modem also restarts it self during this time. Running a 5G and two 2.4G connectio...
Minnie73
Nov 14, 2021Aspirant
this is the model number D7000v2
it is the lastest firmware update availabile. I have the same the same problem on the lastest firmware as well as the previous one.
michaelkenward
Nov 14, 2021Guru - Experienced User
So this isn't the best place to ask for help:
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware.
DSL Modems & Routers
I repeat:
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
