Mozer92
Nov 24, 2020Aspirant
WiFi drops when downloading large files
I have firmware version 1.0.11.110-10.2.100. When DL large files my WiFi shuts off and turns back on. I have already done a factory reset of this router.
Nov 24, 2020Guru - Experienced User
Have you tried the recommended firmware for the router?
A quick search on the forums shows issues with the R7000 firmware.
the agreed upon stable/decent version is 1.0.9.42
I'd recommend installing it over a hardwired connection, factory reset afterwards, and then do a clean install (not from backup).
Mozer92
So install the stable firmware and then do a hardware reset?
- plemansNov 25, 2020Guru - Experienced User
correct.
And make sure to do a clean install. Meaning don't use a backup configuration. If an old setting is causing issues, reinstalling a backup just puts that setting back in there.
- Mozer92Nov 25, 2020Aspirant
Thank you for your help. I will try this.
Curious, how do you know when firmware versions are stable?
