Mozer92
Nov 24, 2020Aspirant
WiFi drops when downloading large files
I have firmware version 1.0.11.110-10.2.100. When DL large files my WiFi shuts off and turns back on. I have already done a factory reset of this router.
Mozer92
So install the stable firmware and then do a hardware reset?
Nov 25, 2020Guru - Experienced User
correct.
And make sure to do a clean install. Meaning don't use a backup configuration. If an old setting is causing issues, reinstalling a backup just puts that setting back in there.
- Mozer92Nov 25, 2020Aspirant
Thank you for your help. I will try this.
Curious, how do you know when firmware versions are stable?
- plemansNov 25, 2020Guru - Experienced User
Mozer92 wrote:Thank you for your help. I will try this.
Curious, how do you know when firmware versions are stable?----By watching the forums. And the R7000 is notorious for firmware issues.
- Mozer92Nov 30, 2020Aspirant
So I have also been having issues with my default gateway is not available. I run Troubleshooting and it resets the ethernet adapter. I have rolled back the firmware version to the version suggested. Today I was getting horrible Upload rates. Like 8meg when I have a 20meg connection. Internet drops out due to the default gateway issue. I reset it. And then my upload rates are fine.
This reset happens randomly about once per week.
