rjmille
Apr 07, 2021Aspirant
Wifi Extender Connected no internet
I set up my wifi extender on the second floor and it helps boost the connection, but as soon as I bring my laptop downstairs, where it is closer to the original router, the whole house loses interet...
Apr 07, 2021Guru - Experienced User
The EX3110 isn't a mesh extender. Because its not mesh, its not seamless. That's why you're running into the issue you're having.
options?
1. keep it as is with the knowledge that you'll need to disable/enable the wifi.
2. change the ssid so you can manually change
3. upgrade to a mesh extender
4. there are a few programs that can force the change. I haven't used them so I can't attest to how well they work but there's app based and pc based.
- rjmilleApr 07, 2021Aspirant
Thanks for the suggestions!
