Jnault1001's avatar
Jnault1001
Follower
Nov 24, 2021
Wifi extender help
My netgear mess extender won’t connect to the internet
1 Reply
  • plemans's avatar
    What extender? Model?
    what router are you connecting it to?
    What mothod of setup did you use? WPS? The installation assistant? App setup?
    you really gave us nothing to go off.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
