fenzinna's avatar
fenzinna
Wifi extremely slow compared to netgear speed test from router... how do I fix this?
Every now and then it peaks and runs a full 350mb/s but most of the time the devices(all -- laptop and mobile) are hitting 5mb/s or less. It's been like this since Sunday. It's not an Xfinity issue. I'm about to return this mesh system back.
  • plemans's avatar
    What router do you have?
    Firmware on the router?
    what modem/gateway is it connected to?
    What wired speeds do you get?
    What speeds over 2.4ghz?
    And over 5ghz?
    What device/devices are you testing on?
    What site/app are you using to test speeds with?
    • fenzinna's avatar
      fenzinna
      it's the nighthawk mr80... the ac3600 wifi 6 mesh system.
      irmware Version V1.1.6.6_3.1.93
      surfboard 3186
      I can't hook up to the ethernet in to a pc but the router's speed test says 350mb/12mb.
      I can't test between the two but my speed test on both laptop and iphone swing from 330+ to under 5mb/s. No in between.
      speedtest.net is the testing site for my mac
      the mobile version is on my iphone.
      • plemans's avatar
        If you're testing directly off the router (shut off the satellites) do you get the same speed?
