Razd
Nov 04, 2021Aspirant
WiFi for large house
Hi, i would like to know what is the best solution for upgrade my R8000 to support my second floor. Appreciate if i can get feedback on the below: 1. connect the R8000 with an Netgear extender via ...
Razd
Nov 05, 2021Aspirant
Thx all for the fast feedback.
So, one good option is to use EX8000, simple solution.
My question is: If i have an option to connect a LAN cable between the R8000 in the 1st floor to the 2nd floor, Is still EX8000 will be the best option or there are otehr betetr one?
Nov 05, 2021Guru - Experienced User
the EX8000 is a great option. It its hardwired in (access point mode) it functions as a triband access point. I've used one and its worked great for me.
- sktn77aNov 07, 2021Virtuoso
Honestly, if you have the option to run an ethernet cable upstairs, do that and get a WiFi Access Point (NOT a wifi "extender") for your upstairs WiFi. I do that with two R7000 routers (one as a DHCP router, one as an access point). The results are far superior to the Google Mesh system (basically a wifi router and a wifi extender) I got with Google Fiber.
- RazdNov 07, 2021Aspirant
Thanks Keith,
Is the connection stay stable when moving from floors? Is it recognized by the same WiFi network name?
