Razd
Nov 04, 2021Aspirant
WiFi for large house
Hi, i would like to know what is the best solution for upgrade my R8000 to support my second floor. Appreciate if i can get feedback on the below: 1. connect the R8000 with an Netgear extender via ...
sktn77a
Nov 07, 2021Virtuoso
Honestly, if you have the option to run an ethernet cable upstairs, do that and get a WiFi Access Point (NOT a wifi "extender") for your upstairs WiFi. I do that with two R7000 routers (one as a DHCP router, one as an access point). The results are far superior to the Google Mesh system (basically a wifi router and a wifi extender) I got with Google Fiber.
Razd
Nov 07, 2021Aspirant
Thanks Keith,
Is the connection stay stable when moving from floors? Is it recognized by the same WiFi network name?
