TheMoltenMan
Apr 08, 2021Follower
Wifi Help with AC1900 (C7000v2)?
Hello. I was wondering if someone could help me with an issue I've been having with my AC1900's wifi speeds. I use Xfinity's blast tier for my internet. It's supposed to be up to 400mbps, which is ...
Apr 08, 2021Guru - Experienced User
that's about what you can expect out of wifi on the C7000's 5ghz. Some devices might get a little more speed if their wifi chip is more efficient.
the C7000 is a modem/router combo device and not simply a router. so it has to share its power/performance budget between the modem and the router. A rough equivelent router is the R7000 and its speeds will hit a bit faster than that but not a ton.
Wifi speeds are greatly overinflated. If you want to read more about it, read this article:
https://www.duckware.com/tech/wifi-in-the-us.html
Something to keep in mind though is that 250-300mbps is enough to do most any tast. Even streaming 4k only uses 25-40mbps. So your games might not download quite as fast but any real time situation (streaming live tv/gaming/etc) should do fine
