Lazz_V2
Jun 28, 2022Aspirant
WiFi keeps cutting out (R7000P)
Hey guys, I really need some help. I’ll try and get all the details I can out of the way right now: WiFi provider: Spectrum Spectrum Modem: E31U2V1 Nighthawk Router: R7000P Router Firmware: V1.3...
michaelkenward
Jun 29, 2022Guru - Experienced User
Lazz_V2 wrote:
Router Firmware: V1.3.1.64_10.1.36
That is by no means the latest firmware. It dates back to 2019. There have been a half a dozen since then.
- Lazz_V2Jun 29, 2022AspirantThe app won’t let me update, is there a way I can update outside the app?
- michaelkenwardJun 29, 2022Guru - Experienced User
Lazz_V2 wrote:
The app won’t let me update, is there a way I can update outside the app?It is all in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.You will also find newer firmware there. The release notes explain how to update.
Check the section in the manual on updating the firmware.Also this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
