Lazz_V2
Jun 28, 2022Aspirant
WiFi keeps cutting out (R7000P)
Hey guys, I really need some help. I’ll try and get all the details I can out of the way right now: WiFi provider: Spectrum Spectrum Modem: E31U2V1 Nighthawk Router: R7000P Router Firmware: V1.3...
Lazz_V2
Jun 29, 2022Aspirant
The app won’t let me update, is there a way I can update outside the app?
michaelkenward
Jun 29, 2022Guru - Experienced User
It is all in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You will also find newer firmware there. The release notes explain how to update.
Check the section in the manual on updating the firmware.
Also this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
