hunter_m13
Oct 21, 2016Aspirant
WiFi light, internet, and alll band LEDs solid white and on, no wireless signal availabe
Hi, I recently moved to a new house and had to reconfigure our router. I reset the router to remove old settings, and configured it as an access point. However, after the router boots up, all LED lig...
- Retired_MemberOct 22, 2016
Make sure you are using correct power adapter
hunter_m13
Also, the channels are all reporting as 0 for wireless, even though i manually set them to 08 for 2.4 GHz, 44 for 5 GHz, and 153 for 5 GHz 2.
