hunter_m13
Oct 21, 2016Aspirant
WiFi light, internet, and alll band LEDs solid white and on, no wireless signal availabe
Hi, I recently moved to a new house and had to reconfigure our router. I reset the router to remove old settings, and configured it as an access point. However, after the router boots up, all LED lig...
- Retired_MemberOct 22, 2016
Make sure you are using correct power adapter
hunter_m13
Oct 22, 2016Aspirant
Apparently I had a netgear range extender and got the cords mixed up. Thanks!
Retired_Member
Oct 22, 2016Thanks for reply most will not admit they used wrong adapter.
Glad it's working again!
