Retired_Member
Sep 29, 2021Wifi Logs
Hello, Are wifi logs available on the nighthawk app? so can the wifi admin browse my profile on the app?
Sep 29, 2021Guru - Experienced User
- Retired_MemberOct 01, 2021
No but i mean as in .. is it available on the app. I on the other thread mentioned the router logs, but I'm curious about whats on the app. Also, do you have to manually enable the logging feature?
