wim10
Mar 09, 2021Aspirant
Wifi network in a big area
Hi all, I have to implement a wifi network in a small village (about 4km lenght for 1km width). I receive the signal with wimax and potentially about 2.000 people could connect. My main goal is to...
lumpy123
What is your budget for the project?
How many potential subs do you predict for the entire service are and for each ap?
What are the service offerings (in regards to throughput and SLAs to the end user?)
How much do you plan to charge customers for the service?
are customers paying for their end device or are they renting, if so could you provde more details on the term
- wim10Mar 09, 2021Aspirant
lumpy123 thanks for your help!
I answer in order:
- What is your budget for the project? About 20k€ for devices (routers, ap, antennas).
- How many potential subs do you predict for the entire service are and for each ap? We could assume about 15 sub networks. Consider that from the wimax central room there are some fiber links until different areas, and from these there are other links. So we could consider that more or less in 15 points we can connect a router with cable and create subs.
- What are the service offerings (in regards to throughput and SLAs to the end user?) at the moment there aren't particular services. In the future we would connect IoT devices.
- How much do you plan to charge customers for the service? n/a at the moment. In future yes
- are customers paying for their end device or are they renting, if so could you provde more details on the term. Now not, in future yes.
- lumpy123Mar 09, 2021Aspirant
Hi there
Thanks for the info, and I hope the question was not too direct.
I was trying to understand if you had a business plan for rolling out a service which is essentially a wireless ISP.
I am pretty new to contributing to these forums, but I think this may not be the right place for you to help build your network.
Given the goals of your design, I think I would be looking to different venues and wireless technologies to address this.
(note - I researched this a year ago so things may have changed as well as products updated. Note also, I dont not work for any of these companies I mention below)
Here are some random thoughts
1- Join a like minded group.
I think you should seek out groups and organisations whos experience and expertise you can lean on. They can give you help which will hopefully avoid the pitfalls which you are bound to run into
One such group here in the USA is wispa.org
There are very small ISPs to very large and all share info , experience with each other.
Again, I am not sure of similar groups in europe, but I would recommend searching
2- Technology selection-
I am open to correction but given your requirements and the area you wish to cover, I m not convinced 2.5 or 5GHz would be of use here.
The larger the network, the more the interfance. The more devices the worse the problem.
In addition I think you will have range issues and connecting all end devices.
Again, If I was you, I would consider other wireless solutions.
Breaking your network down, you should have
A- a design for your backend (billing, accounting, NOC, monitoring, provisioning etc)
B- Capacity injection - You mention you have a Wimax link, which - if it aint broke dont fix, but If I had the money , I would replace with a high capacity E Band long range link (eg Siklu KiloHaul) , its pricey so this is probably out of your range given your budget
C- Backahul transmission- I would consider using an unlicensed band such as 60GHz - 60Ghz has 6 channels in the USA each 2.1Ghz wide and capabile of many Gbps per sector. At 40dBm EIRP you would expect and internode range of about 300meters depedning on rain fade and availability
This would extend your fiber or wimax connection around the town using mesh nodes.
One big caveat is 60GHz is a line of sight technology, so you would need to see the other end device.
There were three companies I looked at before
1- Ignite net - Pros- Easy to install base station and APs, Cheap- Cons- Cheap, big / bulky, I have heard config and planning are poor, small number of channels - The FIAT of 60GHz
2- Siklu Etherhaul - Pros- Large install base, reasonable pricing, solid- Cons - supports 3 channels, sectors are 90 degrees currently, 8 CPE her sector, 4 required to cover 360 degrees antenna alignmnet needed- The landrover of 60GHz
3- CCSL.com - Pros- beautiful small form with 300 degree view, self organising/healing and channel selection, interference avoidance,
No antenna alignment, fiber and relay nodes can be dynamically added without redisgn of network - Cons- Small install base, units as a year ago were more expensive, SON algorithm as of a year ago was work in progress. The Tesla of 60GHz
D- End devices
Residential- Each sub on 60GHz could use a 60GHz CPE from the respective company.
Siklu CPE is a beautiful device the size of slightly larger then a pack of cigarettes, it is capable of 100mbps but requires a key for 1gbps and is very reasonable
The CCS CPE is again small, but a bit larger and a little more expensive then the Siklu CPE.
Each of these claim 300-400 meters range from the node
Care must be given to all these products to dimension the network correctly and ensure the correct number of devices are on each sector
(usually 8 cpe per sector for Ignitenet and Siklu, CCS support 32 over 4 antenna arrays.)
WiFi
With your 60GHz backhaul network, you can also attach devices to the nodes deployed.
For example if you connect a bunch of users from their 60GHz CPE to a backhaul node, you could also connect a WiFi ap to that node and provide Wifi service from that location.
You could also connect anything using ethernet - municiple cameras, traffic sensors, small cells, etc
3- Network design
Once you decide on the technology, I would consider using a company that will help you design the network.
THese companies would give you an idea of where to place the devices and what you can expect from them.
The problem with most of these vendors is they deal only with their product and not the whole network-
I will say that CCS and Siklu work with Adtran in the USA and globally, so Adtran may be a good one stop shop for design, product as well as a suite of products to help build your network.
I will say that even though I mentioned only 3, there are others out there, but these were the ones I focused on.
In Closing-
I would take a good bit of time planning a network and doing a lot of research and selecting bands which will provide what you are looking for, instead of looking for a baindaid or installing the same solution from a different vendor.
I think if you do that, you will be back in the same spot pretty soon.
Looking at pricing as your only guide is misleading , for example, Siklu is cheaper then CCS , but You would need 4 Siklu units to cover a CCS unit- so you will need to do the math,
Again, if I had to pick one from all, I like CCS product.
It allows me to start small , covering a wide field of vision and to incrementally grow the network without continous replans and realignments which is very appealing.
Hopefully what I mentioned above will help you consider other alternatives
As the old saying goes,
Fail to plan, plan to fail
Best of Luck
