cajolino
Apr 26, 2015Follower
Wifi networks drop too often
hi, This router often drop the 2.4 or 5GHz WIFI networks. When this happens, none of my devices (5 of them, including IOS, Android Windows and MacOS) no longer see the WIFI networks. the 5Ghz dr...
- Apr 05, 2016
Hi al59571,
Please check this KB article.
The router has 1 year hardware warranty for replacement from the date of purchase. You may check support team for that.
DHodge87
Mar 25, 2016Aspirant
Any solution yet?
Mine is dropping wifi every few hours and requires a power cycle for it to work.
- JamesGLMar 28, 2016NETGEAR Employee Retired
Hi All,
1. What is the model number of your device?
2. What firmware version currently loaded on the router?
Please perform a reset and manual reconfigure on the device.
