cajolino
Apr 26, 2015Follower
Wifi networks drop too often
hi, This router often drop the 2.4 or 5GHz WIFI networks. When this happens, none of my devices (5 of them, including IOS, Android Windows and MacOS) no longer see the WIFI networks. the 5Ghz dr...
- Apr 05, 2016
Hi al59571,
Please check this KB article.
The router has 1 year hardware warranty for replacement from the date of purchase. You may check support team for that.
JamesGL
Apr 04, 2016Master
Hi al59571,
Can you check this firmware and see if the same problem. Perform a reset after the update.
al59571
Apr 04, 2016Initiate
Hi James,
Thanks for the follow up.
After looking more closely at the router it appears that I do NOT have V2 of this router and it's a V1.
This is the firmware version that I am currently running:
http://kb.netgear.com/app/answers/detail/a_id/29385/~/r7500-firmware-version-1.0.0.94
I've already performed a hard reset on the router to no avail.
This unit is over 90 days old but less than one year old. Do you have any other troubleshooting ideas or know what my options are about getting a replacement device under warranty?
