TSTW22
May 30, 2023Follower
WiFi networks not showing up
When i click on the network tab it shows just my wifi networks and no outside wifi networks. How can I get other networks to show in the list of available networks?
May 31, 2023Guru - Experienced User
On what ?
what router do you have?
What device are you using to check wifi networks?
Are you in range of other networks?
If you're scanning in windows, did you check with windows on why you're not seeing other networks?
