Crypto87
Aug 06, 2022Aspirant
Wifi no internet but ethernet works
Wifi will loose internet access but ethernet works fine. Have to reboot router to fix
Aug 06, 2022Guru - Experienced User
So what NG router are you referring too?
- Crypto87Aug 06, 2022AspirantNighthawk R8000
- plemansAug 06, 2022Guru - Experienced User
What error do you get?
Are you able to connect to the wifi but it says "connected, no internet"
What actually happens?What modem/gateway is the router connected to?
- Crypto87Aug 07, 2022AspirantPhone and camera use the wifi and I have only 2 bars with the cell so I'll notice nothing loads while on the phone. Had a Cisco modem and just upgraded to an unknown modem from both from Spectrum. Same issue with both however.
- FURRYe38Aug 06, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Be sure the wifi button on top of the router is ON. IF thats OFF, press it for 5 seconds then release. Wifi LEDS should turn ON for 2.4 and 5Ghz.
- wcalifasAug 06, 2022Prodigy
Try a different firmware for that router and see if that helps it. Maybe upgrade or downgrade the firmware depending which firmware it has.
Firmware Version is V1.0.4.84_10.1.84
i think the modem is EU2251 from Spectrum. Just upgraded from a Spectrum Cisco Model DPC3010. WIFI internet cuts out with both. Wifi is on just connected with no internet. I have not done a factory reset.
- Crypto87Aug 07, 2022AspirantNighthawk R8000
