Crypto87
Aug 06, 2022Aspirant
Wifi no internet but ethernet works
Wifi will loose internet access but ethernet works fine. Have to reboot router to fix
Aug 06, 2022Guru - Experienced User
Be sure the wifi button on top of the router is ON. IF thats OFF, press it for 5 seconds then release. Wifi LEDS should turn ON for 2.4 and 5Ghz.
wcalifas
Aug 06, 2022Prodigy
Try a different firmware for that router and see if that helps it. Maybe upgrade or downgrade the firmware depending which firmware it has.
