Crypto87
Aug 06, 2022Aspirant
Wifi no internet but ethernet works
Wifi will loose internet access but ethernet works fine. Have to reboot router to fix
michaelkenward
Aug 07, 2022Guru - Experienced User
The lack of detail there may explain why you have had so many different suggestions. (I'd avoid changing firmware until you have tracked down the problem.)
Before diving too deeply, try answering the question that FURRYe38 asked about the modem/gateway.
Which firmware version do you have on the R8000?
Does this happen with all wifi clients?
Then there i the question from plemans "What error do you get?"
