Crypto87
Aug 06, 2022Aspirant
Wifi no internet but ethernet works
Wifi will loose internet access but ethernet works fine. Have to reboot router to fix
Aug 06, 2022Guru - Experienced User
Be sure the wifi button on top of the router is ON. IF thats OFF, press it for 5 seconds then release. Wifi LEDS should turn ON for 2.4 and 5Ghz.
Crypto87
Aug 07, 2022Aspirant
Firmware Version is V1.0.4.84_10.1.84
i think the modem is EU2251 from Spectrum. Just upgraded from a Spectrum Cisco Model DPC3010. WIFI internet cuts out with both. Wifi is on just connected with no internet. I have not done a factory reset.
- michaelkenwardAug 07, 2022Guru - Experienced User
Did you have wifi problems with the old modem?
Did you reset the router when you changed the modem?
That tells it to forget settings inherited from the old modem.
- Crypto87Aug 07, 2022AspirantYes same issue with both modems and I have rebooted the router after replacing the modem
- FURRYe38Aug 07, 2022Guru - Experienced User
Does the router feel extra warm or hot on top?
How do you have Basic wireless settings and Advanced wireless settings configured? Under Advanced Tab/Advanced Settings/Wireless Settings
Your modems don't have wifi or built in routers.
- Crypto87Aug 07, 2022AspirantIt's a little warm. 3 other wifi in range. I haven't done any changes to wifi settings or a factory reset even after a new update
I would try a factory reset and setup from scratch.
I also recommend placing a laptop cooler under the router for additional cooling.
