charleshively
Apr 15, 2025Aspirant
Wifi No Longer Works After Connecting Computers Directly to Modem
I recently connected two of my computers directly to my internet modem via ethernet cable, and as expected the internet is noticeably faster compared when I connected via wifi. However, now my wifi d...
- Apr 16, 2025
I resolved the issue. My problem was that I had the computers plugged directly into the modem rather than the router.
Apr 16, 2025Guru - Experienced User
What modem/gateway ar eyou connected to?
When you disconnected the PC's from the modem, did you power the modem and router off for a couple minutes.
Then power up the modem for a couple minutes, then connect the router to it and power the router on.
There needs to be the waiting times/power off times.
Also, the R6230 is an aged, slow system. Its coming up on time to be replaced. and wired will always be faster than wireless.
- charleshivelyApr 16, 2025Aspirant
- FURRYe38Apr 16, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
