Tina-Mom
Jan 09, 2021Aspirant
wifi off on my r7000
I just lost the wifi on my router. I am into the router settings and I see my wifi is turned off. I cant figure out how to turn it back on. I need help. Tina
- Jan 09, 2021
> Yes, i clicked on the button and it takes me to the wifi setting page.
> It dies not turn on.No, not a virtual button which can be "clicked on", an actual,
physical button on the router. The latest edition of the User Manual is
almost useless, but you might look closely at the rightmost two
LEDs/buttons on the top panel of the router.
antinode
Jan 09, 2021Guru
Tina-Mom
Jan 10, 2021Aspirant
Thank you so much! That was it. I had no idea rhey were buttons. I did find a short sentrnce on page 100and something, but it never said were the button was. Thanks again!
- antinodeJan 10, 2021Guru
> [...] but it never said were the button was. [...]
The design is questionable, and the (stinking) documentation does
nothing to compensate for it. But if you stare intently at the picture
in the manual or the actual gizmo, you might be able to discern a slight
difference in the two rightmost "LEDs".
