dinghar
Feb 20, 2023Follower
Wifi outdoor coverage
What do you recommend when outdoor distance is the greatest challenge? As in, I am having trouble getting a signal to/from my wireless outdoor security camera (in one direction) and to my detached of...
michaelkenward
Feb 20, 2023Guru - Experienced User
Kitsap wrote:For your detached office, go to Amazon and do a product search for powerline wifi extenders. The top rated Netgear PLW1000 shows plenty of good reviews.
Good idea in theory, but talk of a detached office is worrying.
Many electricians, not to mention the law, insist on having a separate fuse box and circuit isolators when they wire an office. (Mine did.) And Powerline does not play nicely in those circumstances. The Powerline signal has a hard time crossing the electrical barriers.
Kitsap
Feb 20, 2023Master
Not worrying at all if you are in the US. National Electrical Code requirements, sub-panels, and circuit breakers do not constitute circuit isolators when both buildings are supplied by the same primary circuit panel. If you are not in the US, further examination would be prudent.
- michaelkenwardFeb 20, 2023Guru - Experienced User
One advantage of having a 120-volt electricity system that is piss poor on the power front.
- KitsapFeb 20, 2023Master
Kitsap wrote:Not worrying at all if you are in the US.
Never been an issue with single phase 240 at the primary panel.
