KathleenAnne
Sep 19, 2022Follower
Wifi Plug in extender for Nighthawk AC2400 router
Which Wi-Fi plug-in extender is compatible with a Nighthawk AC2400 smart router?
michaelkenward
Sep 19, 2022Guru - Experienced User
What do you mean by "plug-in extender"? If you want something that you wire to your router, rather than connect with wifi, then look for an extender that supports wireless access point (AP) mode.
Most do, but it might be harder with some of the "wall wart" things that plug into the mains circuit.
