jamesbwheeler
May 18, 2019Aspirant
WiFi printer problem
After setting up my new Netgrear R6700 Nighthawk AC1750 Smart Wifi router my HP Photosmart 7520 was printing wirelessly no problem like it always had before on the previous network. It worked fine fo...
- May 20, 2019
I resolved this myself. It was just a matter of going through several steps with HP. Here was the start of the solution. https://support.hp.com/us-en/document/c04618676 followed by doing this. https://support.hp.com/us-en/document/c06184808
IrvSp
May 19, 2019Master
I had a 7525 too. I had it 'drop off' the network for one of two PC's quite often. It also did rarely for the other. I'm on W10, but I was always able to solve it with the HP PRINT DOCTOR?
One thing I did find from an older HP310A from HP support was that setting a static IP Address tended to work better. It did for that printer, but not my 7525.
Basically I think it is HP's problem in the driver, I've got a new 7855 for about 6 months now and IT has never dropped off. Same router, same SSID connection, no problems.
jamesbwheeler
May 20, 2019Aspirant
