peach495
Dec 26, 2016Tutor
WiFi problems w/ R7000
I've had this WiFi for awhile without issues runing multiple items through it. Recently I attempted to attach an Amazon firestick to our Smart TV because it predates Amazon Prime. The onscreen menue ...
- Jan 03, 2017
Thank you everyone for all your suggestions. I had to buy a new router & am no longer trying to fix this one.
Dec 26, 2016Guru - Experienced User
What wireless modes are you using on the main host router?
Does the firestick support 5Ghz or just 2.4Ghz?
Try setting WPA2 and AES only on the main host router and manual channel 1 6 or 11 for 2.4Ghz.
peach495
Dec 26, 2016Tutor
The router is 2.4 but the fire stick doesn't say one way or the other. I can't make any adjustment to security on the router because it's not communitating with the modem & there isn't any way to make an adjustment to the unit itself.
