peach495
Dec 26, 2016Tutor
WiFi problems w/ R7000
I've had this WiFi for awhile without issues runing multiple items through it. Recently I attempted to attach an Amazon firestick to our Smart TV because it predates Amazon Prime. The onscreen menue ...
- Jan 03, 2017
Thank you everyone for all your suggestions. I had to buy a new router & am no longer trying to fix this one.
JamesGL
Dec 26, 2016NETGEAR Employee Retired
Hi peach495,
Do you still have internet connection from the router? Since you mentioned that the Internet light is red.
peach495
Dec 27, 2016Tutor
No. I believe it should be white if functioning properly. It's red while it's setting up when first turned on then white when fully operating.
